My brake light keeps coming on and off..
hey guys...whenever i drive my evo...after i pull down my hand brake...my brake light goes off....switching to first gear it is still off...but once i switch to second gear my brake light comes on for a while and then turns off again...do you know what might be causing this problem? any help would be great...thanks
fluid is low because of 1) a leak or 2) pads are low. those are really the only reasons. don't top off the fluid either; replace the pads or you may be overfilled after pad replacement.
BTW, this thread is a repost, use the "Search" button to find pages on this topic.
Originally Posted by xtnct
You will not be overfilled if you take out some brake fluid using a syringe before replacing pads, buy you have to not forget about that step...
