30K mile service
I wouldnt say that any dealer service is reasonable, but compared to others it is around the same. The dealer out here charges 349 or 549 depending if you get a fluid flush or just a drain and refill. If you cant do it yourself i would recomend spending the $ and getting everything flushed
i work at a Stealership and yes they charge 3 times as much as they should, try and find a good mechanich that knows and has worked on Evos in you're area and you shouldnt get screwed. Remember the dealership charges $97 an hour for labor and they go by the book eg: took 1 hour to do work book says charge 2 they charge 2
Originally Posted by evo55
Hayward Mitsubishi is charging $585 for 30K mile service. Is that reasonable or not? TY.
Location: [6][5][0]san mateo, California..."rEpN dA YaY aReA!!"
not sure what we charge at veracom mitsubishi in san mateo but check it out. 30k service, we road test the car first to see if ne thng is wrong, then back to the shop, drain all the fluids, i.e;transfercase, coolent, etc. rotate/spin/balance front tires, top all fluids, check for leaks, n the whole function of the car in n out,n do a final test drive.
Whoa that sucks the same service here in Arizona the cost is 320$ sorry man, but it is alot of stuff they do, andthe service here includes all the fluids flushed! so im going next week.
xphillipjrx
Aug 25, 2004 08:27 PM
