Those With Aftermarket FMIC.....
i dont htink he meant the ams fmic weighs 35 lbs i think he meant the support bumper....but ill tell you one thing when i picked up the ams fmic it was a lot heavier than i thought, couldnt tell you a weight though, im bad at guessing that stuff
Def noticed a differance in power. I have the AMS I/C i left my crash bar in due to the amount of miles and traveling i do. as far a weight goes it does weigh more but it is larger and a differant design. as far as using a jack to put the i/c in it wasn't that heavy, it took me less than an hour to install the hardest part was getting the stock hoses back on.
My buschur weighs a good amount maybe 35 lbs with piping? You probably won't notice it on your butt dyno at first, but up top and on a hot day it helps a little. The lower piping is what gives the power boost. The IC is more for efficiency and doesn't really add much if any on stock turbo. But good to have, especially if you live somewhere southern.
Originally Posted by Kwman
Totaled is a vague term for this incident. Were you hurt? 25 is not slow plus the added momentum of two cars would be much greater than the momentum of one at 35.
Either way, there's more kinetic energy in a single car traveling at 25 (or 35) hitting a fixed object than two cars (one going 5 and the other 20) hitting each other. I believe the equation is KE=1/2 m x V2.
Plus, there are 2 crumple zones in a 2 car accident. LOL
As far as feeling gains...didnt really feel any, but then again I ahvent really got on it to tell....its hot as hell today so Im hoping I feel something nicer at night whens its a little chillier
Originally Posted by CDO
Did you mean 25 (5+20)?
