Blitz DTT-boost gague feature
Does anyone have this? Do you use this feature? Is it accurate at all? Does it display in psi or bar. I'm asking because I want to hit 2 birds with 1 stone, so to speak. It's probably too good to be true and I should just get a defi d series boost gague, but I thought I'd just ask anyway.
i have this. my boost peak relatively displays at 1.34 bars when boost doesnt taper off. this is equivalent to 19.5 lbs. i would say its fairly accurate and is a nice feature. you can also set a warn peak, which is also a nice feature. however, its just mainly used for the turbo timer. but i would/will go the same route as you and getting a defi d boost gauge.
gauge
I have run this tt as my boost gauge for 2 years now. It seems to work just fine. I peak at about 1.36 which is around 20 psi or so. It just took a bit to get the hkpa conversion down. I am going to be installing a full set of stewart warner gauges next month when i change my oil. This should give a better idea of just how accurate the tt is.
i have the dtt and a defi d boost gauge. i like to have a regular boost gauge and a digital boost gauge. also i love how the dtt using the built in boost gauge to run the auto mode on the timer. i dont know if i could live with just the digital boost gauge, but it is accurate
Dr.G
Oct 23, 2015 11:17 PM
Inflation
10
Jun 12, 2008 07:14 AM
smokedmustang
Jun 26, 2006 11:30 AM
