Swapping to MR Aluminum Roof
Registered User
The sunroof assembly weighs something like 35lbs, and it's in exactly the wrong place, up high. So you're looking at dropping 43lbs off the top of the car if you use the aluminum roof skin. That should make a difference.
Oh, in the service manual, there is a different roof support for a non-sunroof car and a sunroof car. I assume it moves the support more to the middle of the roof. Just though you'd want to know.
Registered User
The member pwerks got rid of his sunroof, and replaced the roof skin to put in a cage. He might be able to tell you more about it. Here's a link to the thread:
https://www.evolutionm.net/forums/sh...d.php?t=128170
Unfortunately the links to the pics are all broken now.
Not alot of members are willing to chop their roof for an aluminum one. You said you talk to robi and costs him $1900 all and all. You have to remember, robi has a shop and knows people that knows how to do it. You go and take it to a body shop and it will cost you a grip. Also if they are not good at this type of work, the integrity of the roof will be weak.
Originally Posted by Tsurara
You could say this about any part/install/body work. What is your point? You also forget that a lot of members here are willing to spend 800-1200 on a CF hood which does ****ing NOTHING for weight savings yet everyone is claiming the end of the world over this.
Changing a hood is a complete bolt-on, that's what I was getting at. Swapping the roof requires a plasma cutter and welding. So which is simple? Those guys that gets the CF hoods are usually going for appearance and it's all in the mind about weight savings. Actually compared to some of the CF hoods, the stock hood is lighter or weigh the same. Hey it's your car. If you have the funds and resources, go for it.
i like the idea and i think it would be a good thing, i mean your probably going to change every thing on it, like the suspension and wheels and alot more ****. so really it will be better and cheaper than buying an MR, so i like it.
Kent Jordan's SCCA car had the conversion done... as well as the new APR widebodied RRE race Evo. John Mueller @ RRC has done it.
I hope you plan on racing your car if you are doing this mod and no i don't mean in a straight line...
I hope you plan on racing your car if you are doing this mod.
I wouldnt even consider it if I wasn't. A concern of mine was the roll cage, so this is kind of a must.
i like the idea try and get a black headliner (or dye the stock one) while your at it cause it would make a white car with black leather look real nice! and since installation prices are high you could go all out and get a carbon fiber roof (seen it on a wrx at a show) and its definatly an eye catcher (just an idea) - best of luck
Originally Posted by hkfeet
Did you watch BMI's review on the MR and its light alum. roof? They added some weight on top of the MR to see the difference and they couldnt really tell if the light roof help at all. I dont think it would be worth the money for some placebo effect.
