I just signed my settlement agreement with MMNA
#31
I had a ton of mods on my car and had the 2 front tires wear out at 4k. should my warranty have been denied due to mods....no... I ended up getting 2 new front tires. the dealership found out by aligning the car that it had been out since day one(they say from the straps that secure it in transport). took a few calls to mmna, but they paid, and should have.
#32
$hit no that doesn't sound reasonable. I never said they should warranty wheel bearings if you change your wheels....I SAID POWERTRAIN. Of course, if you put a cat-back exhaust on your car, your cat back exhaust should no longer be warrantied...thats common sense.
I mean, mitsu doesn't make things "standard" because they are the best. They have a target price, and things like wider/bigger wheels and tires don't fit in the budget...has absoloutly NOTHING to do with whats best for performance.
Bottom line is, he did NOTHING to his car to warrant them not fixing his COMMON engine misfire. thats CRAP.
#33
BTW the above is precisely true. Lest I get into double standards whereby mitsu was buying back cars which were modded for this very same problem.
#34
dont forget about emisions standards in america and your 91 **** gas that changes the product Mitsu created. JDM evos handle more power fine, our cars are built to handle JDM power but then the limitations set forth by your "great state" toned it down a little. so should no JDM evo be warrantied or is solely based on the fact that it is different from what you bought from the dealer?
#35
Originally Posted by savaho
It'd probably be safe to assume that one of your mods was to lower your ride as well right? Well, when you lower your vehicle you're suppose to get an alignment and that should have fixed the mis-alignment you claim you weren't aware of when you had purchased the vehicle from day one. I'm the type that can tell if my car is pulling one way or the other on the freeway or street even if it's a slight pull or sway. How do you expect mitsubishi motors to make a profit when they are constantly having to warranty cars with questionable mods? If the aftermarket people are that so much smarter on what improves a car and what lasts longer why don't they build a car from scratch themselves and offer warranties on it? I'd like to see what happens with that. Mitsubishi spends a ton on research and development and then comes up with a product with certain specs that they can vouch for 5-10 years. Altering it by simply adding wheels that are slightly wider may wear down the wheel bearings sooner and mitsu may know this otherwise they would've made 8.5" wide wheels standard. Does this sound unreasonable? Man, I hate to be the voice of reason but sometimes you got to put yourself in the manufacturer's shoes people.
#36
Another piece of evidence would be the idea that people's fuel injectors were causing this problem (I don't know of ANYONE who got rid of this issue by replacing the injectors) and in fact, if they found this to be the issue, they would quickly try to blame the customer/owner for using "race" gas or other gas additives.
#37
MagicManRed
17
Oct 3, 2011 08:36 AM
mr.almeida
Apr 5, 2010 06:56 PM
act, aftermarket, approved, claim, evo, magnusonmoss, mature, mmna, nc, owners, products, rv, settlement, tt, warranty
