Temp in trunk area...
I am probably going to do a small system in my car but what I've noticed is that it's almost as hot as a freaking oven in my trunk. Have any of you guys with systems ever experience your amps overheating in those conditions? I'll most likely be running a single sub like a space saving JL CS110RG-10WO(semi light weight) with a RF Punch 250 that I already own. I have had 3 different sub boxes from JL Audio within the last 10 years or so and have always been happy with the performance even from their entry level stuff. However I am a little concerned about the amount of heat in the trunk though. Thanks in advance.
Dave
Dave
Dave
Dave
I have a system in my trunk(amp and sub w/amp) and have no problems at all. Keep in mind I am in Austin, TX. it is hotter than hell here!! My system didn't even blink when it was 104 degree's here. Hope this helps you.
John
John
Do you play your system loud continuously? My amps are in my trunk here in Houston (hotter than you!!) and pretty much overheat after 20 minutes of loud thumping music. . . .I know in the SSL package the amp is under the driver's seat, so just put one there, and the sub's amp under the passenger seat. . . .the cabin is obviously going to be cooler than the trunk. . .you'll pay more for wiring (I'm not sure how you'll wire to the trunk since it is sealed off as well), but at least your music won't cut out. . .my $.02
No, I don't play my music loud continously(want to be able to hear later in life) but my amps don't cut out at all. Maybe it's your amps?? Not sure where you get that "hotter than you" but that's not quite true, Austin can be just as hot or hotter than Houston. Anyway, if he did decide to do as you recommend and put the amps under his seats first thing I would worry about is heat and then fan noise(if your chosen amps get very hot and/orhave cooling fans). Getting the wiring to the trunk is easy, it is not "sealed off". Remove your back seat and there it is, wide open access to your trunk, running the wires from there is quite easy.
Edit: Ok, I just noticed that you don't even have an Evo!?? Why would you offer this guy this information based on experience when you don't even have the car that he is asking about??
John
John
Cool thanks for the advice guys. I don't really listen to my system loud all of the time either. It's more or less for my enjoyment rather than letting everyone know that I have stereo other than stock. Maybe I should think about installing the amp under the seat too. I know when I drive home from work ( like 18 miles ) I'll pull my work short from the trunk and it feels like it just came out of the dryer after only 20 minutes. Way hotter than my old Maxima. Thanks again.
Dave
I have a system + a computer system running in my trunk. I do listen to music pretty loud constantly. I was very very worried about overheating issues. So far its been 5 months since i installed all of this and i haven't had any problems yet.
dykast
Feb 5, 2014 03:09 PM
Z_Lancer_Man
81
Jul 18, 2004 09:56 PM
