...only boosting 8psi wtf...
Old Aug 2, 2005, 03:39 PM
cliffsevo8's Avatar
Angry ...only boosting 8psi wtf...
ok my evo is only boosting 8 psi it had a magnus manifold,1000cc inj,gt35r setup from south fl prf.,hks cam gears, hks 272s,2step launch control,utech,and wideband o2....but sold all of it went back to stock and now only boosting 8psi? can nyone help?
Old Aug 2, 2005, 03:40 PM
SiCKlEyWiKeD's Avatar
do u still have a flash or did u try and get back close to the stock set up?
Old Aug 2, 2005, 03:41 PM
OZLancerlunatic's Avatar
boost leak
Old Aug 2, 2005, 03:43 PM
Originally Posted by OZLancerlunitic
boost leak
that too
cliffsevo8's Avatar
no flash,and how do you find a boost leak? my boost gauge reads ok...
Old Aug 2, 2005, 03:45 PM
when you step on it you can usually hear it leaking thru your bov that's how i've found one b4
Old Aug 2, 2005, 03:47 PM
cliffsevo8's Avatar
i can here it ....how do you fix that?
Old Aug 2, 2005, 03:48 PM
TRDHarrier's Avatar
1) Wrong forum!!!! (It shouldnt be in Lancer forums AND DEFINITELY shouldnt be in show and shine)
2) Boost leak
3) To find boost leak, get an air compressor or a tank of air, a valve stem, some silicone, plastic cap and a silicone hose BOTH big enough to fit around the turbo and some hose clamps. drill a hole in the cap and put the valve stem in there and silicone around it. put the pieces together and pump 28 psi of gas into the turbo. now listen for hisses
cliffsevo8's Avatar
any other way to tell for a leak?
Old Aug 2, 2005, 03:50 PM
2) Boost leak
wow that's involved
Old Aug 2, 2005, 03:51 PM
cliffsevo8's Avatar
thanx...sorry to post in wrong forum....newbie....be gentle
Old Aug 2, 2005, 06:49 PM
bmericle's Avatar
pressure test everything that could leak.
Old Aug 2, 2005, 06:56 PM
Handmemyarms's Avatar
yeah, i dont think this should be under US lancer show and shine
Old Aug 2, 2005, 06:59 PM
AznFlip's Avatar
^ I know bud, it's already been said.
Old Aug 2, 2005, 07:12 PM
twardnw's Avatar
yeah, wrong forum, but did anyone think to use the handy 'report post' button? (i did)
