First oil change
Old Aug 6, 2005, 10:12 AM
300whpwrx's Avatar
First oil change
well finally got 3,000 miles on the MR and iam going to change the oil.. i want to put in royal purple just wondering if that is ok. also what kind of oil filter should i go with? OEM or some other brand. also how many quarts should i get i couldnt find how many in the manual. there is a missing page in the manual and i think its probly on that page .. well thanks guys!
-wayne
Old Aug 6, 2005, 10:17 AM
2literv8eater's Avatar
These are my preferences, but I'd stick with Mobil 1 great oil and OEM filter, their easy enough to get.
Car takes 5.1 Qts. with filter, 4.8 without, 17mm drain plug.
Old Aug 6, 2005, 10:19 AM
MitsuJoe's Avatar
Wayne,
I would stick with Mobil One through the end of your warranty. They will deny your motor/turbo life if they sense and may even test your oil if you run into problems. I have noticed the OE filter is the best fit and the 6607 Oil filters available are multi application and are too long and skinny to fit properly. The sealing ring works although OE is best that I have found. Also make sure you get yourself a crush washer for the oil plug. Hope that helps.
Old Aug 6, 2005, 10:26 AM
BLKWIDO's Avatar
4 1/2 qts. of moble 1 and k&n oil filter part#(1010) works for me.... my .02.
Old Aug 6, 2005, 10:35 AM
MitsuJoe's Avatar
The K&N is a good filter too. I forgot to mention that.
Old Aug 6, 2005, 11:24 AM
300whpwrx's Avatar
I just bought a greddy TI exhaust and perrin dp and cat delete soo warrenty isnt a worry lol.. I will just go with mobil one since it seems no one really uses royal purple. My last car was a wrx and alot of people just used royal purple. i have about 8 quarts left thats why i was wondering if royal purple was ok.. Thanks for all the help guys!
Old Aug 6, 2005, 11:47 AM
Iceman2011's Avatar
i have been using royal purple with OEM filter for 14k miles now, looks still thin after 3k of driving. i never had to refill in between of 3k
Old Aug 6, 2005, 01:04 PM
madpacket's Avatar
So does everyone get a new washer with each oil change? After my first do-it-myself I was getting a few drops of oil on the floor overnight. Tightened it maybe 1/8 - 1/4 turn more and it stopped, but it occurred to me that the crush washer may have the tendency to get flat over time.
Where would you get a new one?
Thanks
Old Aug 6, 2005, 01:20 PM
vel53oce's Avatar
Mobil 1 and filter, $75-$80 at a dealer, beware
Old Aug 6, 2005, 01:22 PM
o4whtevors's Avatar
i use ELF personaly but im sure that mobil one is fine.
Old Aug 6, 2005, 01:26 PM
Jakeg97's Avatar
hells yeah
Old Aug 6, 2005, 01:27 PM
MitsuJoe's Avatar
You can get the crush washer from the dealer. Do the oil and change yourself and it is less than $30. You can get the Mobil 1 at Walmart in a 5qt jug for around $20.
Old Aug 6, 2005, 03:39 PM
jjm4life's Avatar
stick with mobil 1 that way youre warranty cant get denied just because of oil. do yourself a favor if youre going to have the dealer do it bring your own oil. i just had my first oil change yesterday and it was 65 bucks. they used an oem filter but in my other two cars i used a K and N filter and was very happy with it. also they did change the plug thing whatever its called (i forget already).
as a side note i only had 2500 miles on my evo and not only was my oil low, but it was black dealer said nothing was wrong with it though. weird
Old Aug 6, 2005, 08:12 PM
fletch's Avatar
I am going with Royal Purple myself. I have ran it with great results in my past two cars, Porsche and Mini. Many engine builders use the stuff and it is a full syn. Just my .02.
Old Aug 7, 2005, 01:43 AM
BLUE EVO702's Avatar
5quarts of redline 5w-30 synthetic oil and of those grip fram oil filter...
Quick Reply: First oil change
