Ceramic coating and EGT Bung
How shoujld one go about installing a egt bung when getting the exhaust manifold coated? Should I have thread and install bung then cap off or just thread after its coated?
Are you coating inside and out or just outside?
I would thread the hole, put a plug in there, get it coated, razor blade the edges of the plug, and remove the plug. Make sure to run a tap back through the threads afterwards to remove any ceramic build up.
Or you could drill the hole not tap it. Get it coated, then tap it.
better to drill/tap it prior to coating, and re-tap it after coating, to clear the threads. I did an egt probe after coating, and you'd really have to try hard to screw up the coating by installing an egt probe, but I guess it could be done.
BMS Evo
Jan 23, 2016 07:41 AM
