backfire problems after spark plugs
Hey guys, I just changed my spark plugs and changed my hks filter.
After this, I started getting backfire. pop pop like every other second
Also at idle, my wideband was reading a higher number.
before it was around 15-16. now it's at 20-22 afr/lambda
I put the old plugs back in and the car was still shaky
and reading a high afr number around 17-18, and eventually
backfired, BUT not as frequent.
I pulled each one, one by one and couldn't figure out if
just one of the plugs are bad.
coilpack? what could it be?
thanks
thanks
did you check the resistance's on the coilpack and the plug wires? you can check with an ohmmeter or something similar. I believe resistance on secondary coils are between 8.5-11.5ohms. The spark plug cable resistance should be no greater than 19ohms. hope this helps some.
no i didn't check the resistance, but could the coilpack have gone bad after changing my spark plugs?
i just got tuned for my new cams w/ my safc and wideband.
but i doubt the tune is that sensitive that a spark plug change
and filter could affect it.
at first i thought it was the better flow w/ my new filter
because the wideband was reading leaner,
but i was getting backfire so i was confused.
ngk bpr7es
my car is fine...just stared at my wires for a while and figured
out that i just plugged the spark plug wires back in the wrong
coil packs....DOH!
runs fine now
stressing over my mistakes...you live and learn
coil packs....DOH!
runs fine now
