i need help with bulb replacement please "help"
ok i got one in and it was Fu*#ing hard i took half of the corner panel off the three bolts under the hood and pulled it out a little bit! i also took the two bolts from the headlights out but it barely moved? there is barely space behide the headlight to pull the bulb out! i could just get it out but the bulb in there is really small and the bulb i'm putting in is bigger! i took the plastic clips out from the wheel well it help a little bit
my question is am i missing something i stop with the second one because it got dark but i checked it out and there look like even less space behide the headlight
p.s. i dont know how i got the first one in with out bending or braking something
so dont know how i'm going to get the second one in so can someone help me out here please
and i heard of that book that sell that you use for working on the car if someone has one can you check it out for me thanks if know one has one do you think that will help me out because i don't know what else i should take off and i really don't think i can get the second one in?
any help would be greatly needed
i'm going to mess with it now i have a feeling that i'm not going to get it in!
know one has ever done this before?
i really want to know how to get the headlight out?do i have to take the front bumper off?
Originally Posted by bbyevo8u
i tryed to put it in but no luck i guess i'll just bring it to do you guys think they will put it in for me??
do you guys think i should pay them to do it or should i buy that book that shows and tells you how to work on your car? i think it would tell me what to take apart for this job right?
and what's the book called?
I'm pretty sure the Lancer Evolution service manual will tell you how to do it. Hell maybe if you are lucky the owners manual will tell you. I don't know how it is on the evo but i think you have to remove the front bumper.
maybe u should look under the how to section where it talks about blacking out the headlights and thier is a step by step of taking the headlights out of the car? yes u remover the bumper thier are 2 more bolts under the bumper holding the lights on and a clip.... its extremly easy to do i have had mine out 3 times and i have changed all the bulbs..
thanks for the info
now how hard is it to take the front bumper off?
is there any step by step info of photo's floating around?
thanks agian i was thinking there was another scew or two some where
ok, this is how you remove bumper. very easy.
1. drill
drill below the crest of the bumper on the right and left sides, right below the headlights. yule notice that there's a bolt around there.
2. use a rachet and extension to remove bolt
3. replace bumper
mitsu made it hard for us, everytime we remove our bumpers, we have to buy a new one.
1. drill
3. replace bumper
