Innovation and EVOlution in the aftermarket - the NEW best MBC for EVOS!
#31
Originally Posted by DynoFlash
Yes - just pay pal $89.00 to paypal@dynoflash.com I will cover the shipping
#32
Originally Posted by Mike@Forge
Here is a better picture of a production unit:
Mike do you know if there's a way or if Forge can find a way to mark the setting. It doesn't have to be precise but a way to mark a 20psi and 25 psi (example)setting. It might sound dumb but it would be nice
#36
I picked one up. Anyone want to buy an AMS MBC?
If this product is anything liek the BOV then I am sure there will be no disapointment. Why else would Al buy every one they have.
#38
However, I am even a bigger fan of Forge and I have been using the Forge BOV, header tank and power steering tank on my race car and the quality of the product is the best you can buy.
When I installed the new Forge MBC this weekend and saw how well it works I was amazed. I figured it would be MORE money than the hallman as it is better quality and it comes with two brackets, not just a rubber hose clamp. When I saw that the retail was a amazingly good value at only $89.00 - LESS than the Hallman - well then it was time to buy as many as I could get my hands on!
For $89.00 you can not beat this unit. When some of you start to see it on other cars you will be amazed.
#39
Also, there is some overlap between the two springs included with the unit so a higher setting on the soft spring will equal a lower setting on the stiff spring in some instances on the same application.
Having a boost gauge is the best way to tell what you will be boosting to.
#40
Originally Posted by fsugatorbait
Al, given the 3 cars you've tested with this unit, what were your findings? How much more boost did this hold vs the MBCs that were previously installed on the cars?
MBC's such as the TX's unit which have overly large bleed holes leak off topo much air flow on evos and the boost will have a huge spread falling as much as 5 - 6 psi towards red line
I especially like the accuracy of the clicking adjustment knob on this unit and the precisise way it adjusts the boost
#42
This is really not a feasible possibility because many people will be using these on numerous other applications as well as on vehicles with different base settings for their wastegate actuators or external wastegates.
#43
Originally Posted by 03EvolutionVIII
Little help???
Linear adjustability - meaning that when you move the knob half a turn you get the same change in boost each time
Steady target boost holding - the design is such that it reaches target boost quickly and holds the boost at the desired target as long as possible
Durable
Good looking
Quality of materials
#44
OK... Why go MBC over EBC? To me it same easier to use a EBC over a MBC.
To me the things that make a MBC good - or things to look for in the design are :
Durable
Good looking
Durable
Good looking
#45
Totally understand and I wasn't talking about a spring set to a certain psi level. What I was asking was a way for us to mark the bov once we have it set to the boost level we want. I know it's not acurate but on my AMS Bov I color marked it (using a pen) so that I can turn it close to 25 psi and back to 21 psi without too much trial and error.
Should be pretty simple to keep track. Just keep a post-it note in your car!
