Apexi GT-spec downpipe "specs"
Old Oct 17, 2005 | 10:51 AM
SpoonEvo's Avatar
Originally Posted by nightwalker
I haven't tried the protective spray on wraps yet, but I will tell you guys from personal experience that wraps eat the metal underneath, and causes it to thin out, eventually cracking whatever it is you have wrapped.
I'm affraid of that...but is the heat wrap a must? I know wat it does, but w/o
the wrap will it effect other parts in the car?
Old Oct 17, 2005 | 11:22 AM
Mr. Stock's Avatar
Any "hot rod" store will have it. Can't remember the brand off hand. I'd have to go home and look. For longevity, stainless steel will do MUCH better than mild steel. I can't see anything happening to stainless in less than three or four years. It's necessary to be careful when wrapping it, specifically, uniform spacing and 1/2" overlap. My RX-7's downpipe is mild steel and I've not had any issues in the two years it's been on the car since I swapped over to a big single turbo.
Old Oct 17, 2005 | 11:24 AM
Mr. Stock's Avatar
There are all kinds of thermal barriers including stuff from Thermotech (Jegs or Summit Racing) which has an adhesive backing. You could clean the oil pan well and then stick this stuff on.
chaotichoax
Apr 13, 2020 12:55 AM
EgoKillerEVO
Nov 29, 2007 08:08 PM
Mike@Forge
97
Oct 3, 2006 03:20 PM
teamdomokun
Feb 23, 2003 04:19 AM
Quick Reply: Apexi GT-spec downpipe "specs"
