What is the highest octane gas that is safe
Location: Inbetween east bum f*ck and you've got a pretty mouth
Im going to the track and they sell raceing gas. What is the highest octane gas I can use with out killing an Evo VIII.
\\\THANKS///
\\\THANKS///
Just make sure you don't use LEADED race gas if you have a cat of any kind (stock or HFC). Leaded gas is usually of the 110/112/114/116 variety. If you have a cat, then make sure you only use unleaded race gas. These are usually 100/102/104, but make sure and ask the attendant beforehand. None of these are unsafe for the Evo, but the leaded octanes will eventually foul your o2 sensor if you use it a lot.
what the point of running the highest octane you can if you arent tuned for it?? If you just want to run race gas for safety purposes, a few gallons of 100oct mixed with a few gallons of 93oct should be safe enough
trinibt65
Evo X Dyno Results
Apr 27, 2016 11:11 AM
