Safe to run evo at 12 psi on 87 octane?
Originally Posted by eve-slow
NO offense, but it sounds like you need a different car!
None taken. Honestly, the gas bill I can afford. I just get so angry when I fill up that it really takes alot of fun out of driving the evo. I feel like I am getting raped, and I guess everyone else on this board feels the same way.
Bobby
premium in usually only 20-30 cents more per gallon, thats should not make or break anyyone. If you're already paying 3.50 per gallon I am sure a few more dollars to fill your entire tank won't be that big of a deal. I am sure you can make small sacrafices to put the right fuel in your car.
Yeah you can run 87 no problem, just dont floow it, as long as you don't boost, your compression ratio is SO low that you would have an issue, In fact just disconnect your wastgate actuator, your car will be slow as **** but run 87 like a champ
Originally Posted by HwangTKD
It takes me about $50 to fill up....I fill up about 4 times a week! My projected monthly gas usage is about $800 And thats if I be GOOD with the right foot!
Bobby
Bobby
motha kcuf
