Explain the re-flash thingy?
As I understand it someone reprograms the ECU to compensate for certain mods? Are there local speed shops in ones own state who can do this or is there only one guy? Also if you are just adding say an intake and cat back would a reflash be neccessary or only after major things such as cams?
Thanks Dean
Thanks Dean
for intake and cams you'll need a flash or tune of some sort, but not exhaust.
flash is just a way for the tuner (such as dynoflash, vishnu, turbotrix, buschur etc) to rework your ecu to a set map (afr, timing, so on and so forth) to work with your mods (or even stock)... i'm sure someone can explain it in more detail, but you can do through-the-mail flashes, where you take out your ecu and send it to a tuner with your mods list and they'll flash it for those mods but it won't be as accurate as actually doing a dyno tune. unfortunately not that many shops flash.
you just sent him a list of all your mods along with your ecu and he flashes it adding more horse power to you car and ihave to say it is great i like it more and more it is a good thing you also won't be running ritch
Thanks Dean
Thanks Dean
The jist of it is ,, Mitsubishi sent these cars to the US , super conservative. By simply re-flashing the Eprom on the Ecu. Its changes the ignition and fuel mapping resulting on average about 20-40 whp gains..
Also you can take out boost cut, top speed limiter, and raise the rev limiter ..
Good luck
Mark
Turbotrix
I like these posts. Nice and simple replies.
One question: Is a flash required if you have an experienced tuner work on your piggy back ecu (like xede)?
AC556K: I still fail to understand why you refuse to search. You've already started 3 separate threads asking the most basic and inane questions. I expect more from someone who is able to afford a convertible M3, but I guess money and brains don't always come in the same package...
If you have a piggy-back, you don't need a flash.
Go easy on the guy. Maybe he did try to search and found that the answers contradict (as I've noticed also on certain topics) and decided to ask again.
All we wanna do is learn from you guys so please dont flame me for this reply. (by the way, thanks for the spark plus tip (thats me sucking up)).
Hey Warrtalon,
There's no way he searched on flashes and still had to ask that question, because there is NO CONFUSION on what a flash does, and it is one of the most basic and fundamental modifications for Evos. Unfortunately, he will probably continue his idiocy, because as you see, he only responded with a sarcastic remark that makes no sense while completely ignoring the SEARCH advice. I hate babies who look to be spoonfed...
Yea, I won all my stores in the Florida State Lottery and with the help of my dog manage to keep them running. In fact that is actually a Hyundai with a body kit . Anyways thanks to the helpful guys/gals on this forum who can offer constructive advice .
you own a bunch of stores and all you can afford is an m3? I know a 25 year old who works at a deli and he has an '04................................
