Question about using a Honda battery
Old Sep 14, 2005 | 11:21 PM
NocturnalEVO's Avatar
Hey all,
I'm wanting to run a mini-battery kit so I can get a nice flowing upper ic pipe, however I will also be running a navi system, a 10" sub, and some other electronics.
With all the mini-battery kits out on the market, they're not really great for running accessories..
So I was thinking of running a smaller battery, like a 51R (comes stock on the TSX's/RSX's), and OPTIMA has a 51R in a deepcycle which is great.
As long as I can custom fab some kind of tray to hold it in place, are there any drawbacks, or any reasons why I shouldn't get a battery in that size?
If so, please let me know.
thanks in advance!
- Najeeb
Old Sep 14, 2005 | 11:25 PM
alex s's Avatar
i don't really see why it would present any kind of problem, i mean a battery is a battery when it all comes down to it. i'm talking when comparing car companies, not individual batteries. my S2000's battery was pretty small too, could always check into that.
good luck, and let us know how it turns out.
Old Sep 15, 2005 | 01:33 AM
thanks!
Can anybody else comment in on this?
Old Sep 15, 2005 | 02:11 AM
jxn evo 8's Avatar
I am not sure but doesn't the battery only start the car? the alternator is what really is in question when you start putting alot electronics in a car. I know that in police cars one the up grades is that these cars come with larger alternators to powere the electronics in police cars. I could be wrong I was just going to throw that out there.
Old Sep 15, 2005 | 02:28 AM
negativeB's Avatar
alternator only works while driving the car. it can't power the accessories(radio, etc.) while the car is off, which is where people with small batteries run into trouble.
Old Sep 15, 2005 | 02:30 AM
yea i'm gonna need a deep cycle battery for running the stuff while the car is off. I do a lot of car shows, and at some of the carshows, u can't have ur car running.
Old Sep 15, 2005 | 02:36 AM
jxn evo 8's Avatar
o ok i guess i just miss understood the question my bad
Old Sep 15, 2005 | 02:56 AM
2hot2handle's Avatar
it depends, yea it might be smaller in size but you have to look into CCA (cold cranking amps). gotta make sure it can support what you alternator can charge.
Old Sep 15, 2005 | 03:05 AM
how much can our stock alternators charge?
Old Sep 15, 2005 | 03:08 AM
Here's the specs on the 51R battery (from optima)
Size (inches) 9 5/16 x 5 1/16 x 8 15/16
Minimum Weight 26 lbs
Voltage 12V
Cold Cranking Amps 500
Reserve Capacity 70
Capacity (C/20 Rate) 41 Ah
Type Post/Terminal SAE
BCI Group 51R
Old Sep 15, 2005 | 03:10 AM
jxn evo 8's Avatar
what is the cold cranking amps of a stock evo battery?
evo_what
Jul 1, 2008 03:09 PM
tseitz123
Aug 19, 2007 09:37 PM
inariv5573
16
Oct 28, 2005 12:48 AM
NocturnalEVO
May 15, 2005 08:33 AM
BOOSTEZ
15
May 11, 2005 04:34 AM
