Helix Center Guage Pod and Evo MR Guages
Will my Factory Evo 8 MR gauges fit the Helix Center Guage Pod? Does the Helix Center Guage Pod tilt the gauge toward the driver?
Can't get a response from the 500whp.com.
Helix Center Gauge Pod - Evo 8
If not, is the any alternative. I swapped the radio and factory guages.
Looking for something better.
I am pretty sure.. they will NOT fit.
the cheep gages that came with my MR are like 40mm in size.. I am sure that pod hold 52mm gages
you could whip up an adapter if you wanted to .. but they will not just fit in.
not to mention.. I would recommend getting better gages anyways.. the ones that came with my MR,
Boost (in bar.. YUCK!) and never seems accurate
Oil Temp never moves high enough to look normal
Volts (who needs that, most Turbo timers have em built in)
get an EGT, Oil temp, fuel pressure and put a boost gage on your wheel
