all ACD leds are on . Can anybody help
Brand new to the forum .. with a EVO 7 ( Auto ) I can hear the laughter already ... imported from Japan . I have all the ACD leds on .I was hoping somebody might have a idea and a safe way to re-setting them . The ACD button doesn't work either . Thanks a million .. Autoevo ( Australia )
All ACD lights on means that there is something wrong with the ACD system.
Did you try resetting the battery? This may work if it's just a minor glitch in the ACD ECU computer.
Is your Anti Lock light on? I remember the combination of the Anti Lock & ACD lights on once and it ended up being just a fuse that had shorted. The USDM Evo has the Anti Lock, ACD and Climate Control on one fuse.
couple things to check.......
first is your car temp. gauge working? if its not, then check the fuse. its wierd i know. for some reason had an idea to where if the car was not at operating temp. by a certain time, that would throw off the ACD.
if your car temp gauge is working, make sure that your fans turn on when there suppose to. if your whole engine temp. readings are screwed up, that can again throw the ACD off.
reason im saying this is, about 500 miles into my car (have 1050miles right now, so still new) my temp. gauge stopped working, but my fans still turned on when they needed. because of that, my ACD lights would all stay on while driving. well for some reason, a fuse blew that controls the acd/temp gauge. i took it back to mitsu and in 5 minutes they replaced the fuse and my temp. gauge worked again and i was able to switch my ACD controls again. I know its wierd, but check it out.....
Thanks for all the support .. If I do find a way around the "ACD " problem I will post it for other memebers who might get the same problem ... Even though the "ACD" leds are on ... the car still is working perfectly .... Thanks Autoevo
Possible electrical glitch if you have not reset the battery yet.
from the manual before assuming the worst
Is the appropriate steering wheel installed at the center of the steering column shaft correctly?
Are the tire, wheel size, specifications, air pressure, balance, and wear state normal?
Is the wheel alignment normal?
Has the engine, suspension, etc. been remodeled in such a way that it will affect the ACD and AYC systems?"
Hi there ... The car was running perfectly ... we changed the Air-fiilter and when i re-started the car the ( ACD LEDS ) are locked on. I will disc-connect the battery for 40 mins and see if this will re-set the computer . Looking through heaps of pages of faults that memebers have reported ,I can't find any issues with the the ACD leds . Who knows I might be the first to have this issue. It doesn't seem to effect the car's performance in any way . But I was hoping its something simple ... Cheers Autoevo
Spins_All_4
Aug 28, 2012 09:45 AM
WillEatUrSTi
17
Feb 23, 2006 11:51 PM
