gsc cams nightmare
gsc cams nightmare
Edited the post. Will send the cams to greg at gsc to get measured. You may close the thread. Sorry for all the rant it may have caused
Not too sure what to think here. The GSC 272's have the exact same lift as the stockers, 264's, and 280's. Unless your specific cams happened to be manufactured wrong, in which a higher lift was produced for the valves in cylinder 1 and cylinder 4, that would be unfortunate. I highly doubt, however, that this is the case. I dont want to blame the cams nor your installer, but i would look into it more...did you look at the GSC's?? do they appear to be faulty?? Secondly, how reputable is the shop that installed them?? You say they are, but they still could have made the mistake, not the cams.
If I understand you, you are saying that the cams are ground incorrectly.
This should be easy to check with a pair of calipers.
If this is the case, you may have some recource with GSC to pick up the cost of repairs.
Either way, i WOULD send the cams back to GSC and tell them what happened, and have them check the specs on them. If they are faulty, they hey, you will probably get that damaged paid for.
Nick!! lucky you, work = play now huh))
Highly doubt it was the installer, he's done this plenty of times without any setbacks, plus we had a pair of hks cams sitting there and installed those with out any problems, so if the car was not timed or the belt skipped, then the exact same thing should have happened with the hks cams, it did not. I would be a good idea to measure them, and there is such a bad thing as bad luck. You could make 99 that work, but there's always that 1 %
Besides, it's not hte first issue. One of our friends bough a pair of gsc's and had to send them back because they wouldn't fit, greg from gsc was a stand up guy and changed them
Originally Posted by taenaive
I bet the installer made a mistake putting back on. The valve problem suggests that He missed TDC location of timing belt when he put the belt on cam gears.
+1
^^ so i'd contact GSC, you're looking at major repairs here and if you don't think you or your installer are responsible, send them to GSC and talk to the guy you know over there (Greg). Sorry to hear that bro
seriously, why did he have to put on other cams to prove that the gsc's are off? i bet he found tdc when he put in the hks cams. a hour or two of labor vs. a few minutes with a caliper. sounds really fishy. but good luck none the less.
my vote goes with installer.
