Low Beam Headlight Question
I've decided to go with some Silverstar's to give me some better visibility. I've got the part numbers, 9006 low, 9005 high.
These are the same bulbs my Contour SVT used. What I did on the Contour is replaced all four of them with 9005's. The 9005 just has an extra tab on the inside of the housing that can be shaved off with a razorblade and fits just fine in the 9006 spot. Worked great in my Contour, and provided high beam brightness at the low beam angle so as to not annoy other cars.
Has anyone done this to the EVO? The wiring for the low beam and high beam should be the same, so it's not like the extra load will burn up the wires or anything. Does anyone know of a reason it worked in the Contour but wouldn't work on the EVO?
Originally Posted by dridge11
HID = More expensive than Silverstars
Trying to find the cost effective solution.
I'll do some more research on exactly what bulbs to get. I had a positive experience with the Silverstars before and I'm a brand loyalty kind of guy.
Macky, I have also heard it's not "technically" recommended, but I've never really seen a good explanation of why.
In my experience, Silverstars have been trash in terms of bulb life. I've never had a bulb that lasted more than a year (although I've heard of people who've had Silverstars last longer), which is about what Sylvania expects. IMO, paying $30 every year to replace a set of bulbs isn't *too* bad, since overall it's still cheaper than HIDs. The problem I had is that the bulbs could go out spontaneously while I'm driving, which is a big no-no for me due to the obvious problems with regards to poor lighting/police until I got them replaced. Plus it's a hassle to drive down to the local Pep Boys/Wal-Mart everytime they went out. Eventually I just retrofitted some HIDs+projectors into my car.
Originally Posted by ttiscio
Sorry to go a bit off here, but am I missing something? Are HID's an option on the newer EVO's?
Bulbs should be replaced every two years anyways, they get dimmer as they age (filaments thin).
9005 conversion from 9006 is fine, but the 9005 is a shorter life bulb but much brighter.
Whiter than silverstars:
www.hoen-usa.com
www.hoen-usa.com
besides that, all you have to do to make them fit is chip off with a plier the tabs to make it look like the 9006 fins and the 9005 bulb will fit to the 9006 socket. oh and before plugging the power socket, if you look into the socket of the 9005 and compare it to the 9006, you will also need to trim two smaller tabs inside the socket itself (just use a pairing knife or small swiss knife) so that the 9006 power socket will go in with no problems.
other than that you should be fine. good luck
