Guess my Dyno #'s
Guess my Dyno #'s
Im going to get dynoed soon and i was wondering what you guys think i should expect outof my car here are the mods:
Full 3 inch turbo back with high flow cat and custom bent dp
buschur intake
hallman at 21 psi
dynoflash base flash
buschur intake
hallman at 21 psi
i would suggest getting 272/272 it would just fine. a lot of people running around like *****es about rough idleling, well it doesn't matter 264 does the same ****. if you going to paid for something might aswell get the best. HKs are good stuff, but i have seen GSC pull some good number aswell. Stay away from Buddy Club unless it's really cheap. You don't need Cams gear, stock one are just fine. You might wanna run SAFC II along with the flash or run it alone. MY made 345whp with a boost leak, but now i fixed it, can't wait to dyno again with my RNR 3037 kit on it ways.
260-300... but 300 is pushing it... (and this, of course, depends on the dyno, and whether you mean whp or bhp)
HFC tends to make 10-15 less hp than catless, that's why... And now that I thought about it a little more, since it probably isn't Mustang or that other low reading one (Dynapak, i think...) and since you are boosting more than I am on better gas... I imagine much closer to 300-310 than I first suggested.
buschur intake
hallman at 21 psi
buschur intake
hallman at 21 psi
My money is on 295-300 with the mods listed. 295 with around the same amount of torque. I personally believe that more is attainable but the average owner isn't going to see the touted gains of other cars. My car is A dog I believe because I did 309/304 with TBE, FP, Custom Harman flash, and a BC set at 24ish on 104 oct.
. Good luck and hopefully you hit your mark.
