Injen Intake w/ hks ssq vta
Does anyone use the Injen Intake w/ the hks ssq blow off valve set up. Im wondering if the flange can be welded into the pipes or the metal is not the right kind or too thin. Does anyone have this welded into the inken upper ic pipe, if so can u please post pics. thanx
If you already bought these, then of course you can weld a flange on the UICP...
Originally Posted by EVIL EVO 8
stock drop in's are usless almost, intakes will give you so much more boost response,
Have you already bought both of these items? If not, I'd recommend not getting either, but rather a drop-in filter and JDM MR DV while retaining the stock piping. You will save $500 and the car will run better.
personally I went with a k&n with a MAF adaptor and the APS BOV.....I raced an MR with the exact setup you want when all I had was a stock car and smoked him. He couldnt believe that I had nothing on it. Could have been the driver too, but that is my experience
Deceit
15
Oct 15, 2003 02:02 AM
