The black EVO From FL Comes back Home
#649
Originally Posted by sleet
So go from a roll, not alot of driver skill involved there. You simply put it in gear and hit the gas
Eric
#653
Originally Posted by AutoMotoSports
you have never driven a 800 hp car before have you.. lol There is still alot of skill even on a roll. Keeping it stright, hitting the gears right. playing with the throttle to prevent wheel spin in the lower gears. All that plays into consideration.
Eric
Eric
Are you guys doing anything to the engine to built it up further or recondition it?
#656
after reading this whole thread from begging to end tonight I can say that I can't wait to see this thing up and going.
This car has gotten tons of props from everywhere on the net and AMS has grown even more well known cause of it.
Hummmm yall ever done anything with an SRT-4?!?!?!?
#657
check their site - they have a vid of an SRT-4 on the dyno putting out some impressive numbers.
#658
Originally Posted by 05WhiteEVO8
I was thinking a roll run as well, this way you can see how the stroker compares with the higher revving two liter
#659
^ ever since day 1 of the videos coming out, you have tried to make nothing but wise remarks or any other remarks to make Chris's car seem to be not as bad *** as it is. Though I will give it to you, I do not recall you making a directly comment cutting his car down, but you certainly have made several indirect comments to try and make it seem, as I said earlier, not as bad *** as it is. At first it was kind of amusing to see the indiect comments you came up0 with, but after a while(aka now) it has just gotten boring and quite lame.
#660
Well Chris will be at a little disadvantage as he will not be used to his car, but maybe if someone else who is used to the 42R spool and shifting drove then it would be a better indication. Just some ideas. Chris probably wont let anyone touch it once hes up there though LOL. I wouldn't either .
