No cruise control
#31
Here is a few choices for cruise kits that will work on the EVO.
http://www.rostra.com/ac-cruise.asp.
http://www.jcwhitney.com/autoparts/B...uise%20control
#32
I dont post much, but damn!!!!
Guys in the US complained for 8 years+ because Mitsubishi didn't bring the "rough and tough" Evo to the States. Now they did and people complain about everything. I also came from a BMW M3. The Evo is no M3 but its such an awesome car I can give up its short comings (it has a lot of them) for its raw performance.
Stop *****ing or else Nissian won't bring the Skyline.
Pete
03 Evo (lots of go fast goodies)
04 Yukon Denali (also with goodies)
Pete
#33
Just a thought....in the last episode of Top Gear here in the US, they drove a twin turbo Audi A8 diesel 800 miles and found out that using cruise control wasted more gas. Personally, I never use cruise control in my other car even when driving from SoCal to Phoenix. Trying to maintain the same speed for a long time helps keep me awake.
#34
Where I live the police follow you, Just waiting for a reason. I once drove in circles til the cop stop me.
Rostra has a kit specific to the evo. Go to http://www.rostra.com/cruise-control.htm.
Answer the questions and the kit is displayed.
04 MITSUBISHI LANER EVOLUTION
CRUISE CONTROL
250-1223
Control Lever: 250-3421,250-3742
Adapter: NA
VSS Wire: LOCATION 2 22PIN CONNECTOR
VSS Wire Color: BLACK/YELLOW
VSS Pulse: 4000
VSS Tach Wire: NA IF MANUAL MUST USE CLUTCH SWITCH 250-4206
Tach Signal Wire Color: NA
Brake Switch Positive: RED/BLACK
Brake Switch Negative: GREEN
Click Here to view wiring diagram.
NOTE: Please consult the Owner/Installation Manual for further informat
CRUISE CONTROL
250-1223
Adapter: NA
VSS Pulse: 4000
#36
Originally Posted by Euromagination
Last month I took the Evo from Princeton, NJ to the Outer Banks in North Carolina--about 600 miles or 11 hours each way--and I didn't think it was that bad after the first hour or so, I just got over it. It's more fun to drive without cruise anyway, and I think I'd get bored and go to sleep if I used cruise. Every other car that's ever been in my possession has had the option, the Evo is my only exception. Either way I rarely use it, and I go on many road trips.
That said, cruise is a little overrated.
Keepin' the tach in the middle with both...
-'04 Evolution VIII
-'93 Porsche 911 Carrera 2
-'04 Evolution VIII
#38
CRUISE CONTROL
250-1223
Adapter: NA
VSS Pulse: 4000
CRUISE CONTROL
250-1223
Adapter: NA
VSS Pulse: 4000
no, the lancer stuff won't convert, the controls won't fit on our wheel.
and exactly, i'll be sitting there doing 78 in a 70 and i'll look down and i'll be sittin on 90-95. Simply too easy to gain speed. With the cruise, other than mountains as before mentioned, you can keep a same pace.
there is NOTHING more annoying than driving a car on a road trip and passing a person, then them passing you back and getting in front of you and slowing down, then you passing them again...etc.etc.etc.
chase2000gt
Jul 5, 2005 05:56 PM
