how much does your evo weigh?
#61
humm i need to go to the track and weight car on a real scale. i will do when get warmer out. and there so many diff weights for all parts need a scale that is on the money with pics of parts lol
#62
not that the rear seat weighs anything.
Rear seat bottom cushion: 9.5
The rear seatbelt hardware with child safety anchors and all that weigh 12.5lbs
spare tire: 31lbs
Trunk base, trunk panels, jack, floor mats: 17lbs
AC + condensor + front beam: 51lbs
Cat delete: 10lbs
Floor mats: 5lbs
PF 2 piece rotors: 4lb reduction over stock rotors
Stock struts to coilovers: 18lb reduction
Stock recaro: 37.lbs, replacing with spraco evo: 11.8lb reduction
Stock battery to Mini battery: 18lbs reduction
202lbs reduction right there. It adds up.
I have no idea how much I save with a aftermarket catback and downpipe.
#63
wow very nice. you weight that stuff or somthing. lol. and full tbe can save like 40lb i kno stock they say is 60lb. and br tbe is like 20 or somthing so bam 40lb. how about sunroof, door panel, carpet, sound det, center consol arm and cup part, sound system ssl package one. and you sure the rear seat belt all 3 and all dont weight more then 12lb
#64
Originally Posted by slickevo18
whats up all, just kinda curious how much your evo weighs!
my 03' evo gsr, weighed almost 3400 pounds stock.
we were able to get it down to 2951 with 1/2 a tank of gas! still got a passenger and back seat, door panels, center console and dash..... can you beat that?
https://www.evolutionm.net/forums/sh...d.php?t=117853
#65
Originally Posted by evorent
my only 2020lb
lol thats not an evo any more total diff frame and all. does not count.
#68
to bring back a old thread....one could also
install the buschur rear mustache bar and side diff plates: 20 lbs off in the rear
AMS front crossmember bar: 10 lbs off in the front
AMS roof (depending on which model you have): 15-40 lbs off the center
Carbon doors: (4doors w/ plexi): 120 lbs
Carbon doors: (rears w/plexi): about 50-70 lbs off
Changing all your glass to plexi: 60 lbs off the car
Sound deadening material (all): 40 lbs off car
Driveshaft: (stock) 60 lbs Carbon shaft: 30 lbs
it really would add up if you think about it..
slickevo18
Mar 2, 2008 07:22 PM
