ok im pissed with all these loud exhausts
#76
I think you need to find your price range first, then find a exhaust that is quiet enough to your approval.
But get the car and then worry about the exhaust is probably the best way!
#77
You don't have to contact us directly for the $825 price, you can order via online if you like. You will be charged the $825 regardless of what the online ordering says, we would correct it as to not rip anyone off.
David Buschur
www.buschurracing.com
David Buschur
#78
I assume that you want it to sound good as well as quiet.
The best bet is to go with a system where you have the same diameter fron the turbo back. Changing diameter abruptly will make really annoying (and sometimes loud) noises at a certain rpm or when you back off the throttle.
I have the Tomei turbo outlet, Mine's test pipe, and Greddy Ti. Funnily enough, it's not all that loud. [all are same diameter].
The best bet is to listen for yourself. It is possible to make an exhaust sliencer to keep things real quiet at say, 3000rpm and go ape at 7000.
Even worse is just to look at the dB rating. It's a log scale, so a 3db difference is about 10times the sound pressure level. How much a loudness increase will be perceived it totally different again.
p.s. I think it's illegal to employ someone to work in an environment of greate than 120dB without ear protection....
#80
Instead, we use the dB A-weighted scale, or dBA, to more accurately represent what our ears perceive. Using a dBA scale, I have tested exhausts before at a local Evo meet. Ranges were generally from the stock 74dBA, to 82dbA HKS/JIC exhausts, 96dBA Buschur (with racing muffler).
96dBA, measured at about 3 feet from the exit of the muffler, was pretty damn loud. I imagine the sound is somewhat dulled from inside the cabin but I cannot imagine it to be much better. Since everyone's ears are different, and people with damaged ears will have a better tolerance for louder noises, my suggestion stays - to hear them for yourself in person.
#81
Thanks for the correction.
It's a log10 scale. So 10dB difference is 10x greater. So yes, you're right 3dB would be about double.
My point is that while the numbers tell you which is louder, the relative difference shold really be heard.
From what I have seen, most sites advertise loudness in dB, and not the weighted dBA, which as you point out would be more accurate. I don't know if the meters measure and weight the value and dB in this case actually implies dBA.
#83
Note: My Greddy is a Power Extreme Ti and _NOT_ the Power Extreme Ti-R which I believe is fairly mental (93dB @ 4875rpm).
The Ti (no R) is Jasma compliant, which is a Japanese noise level standard of some type. I don't know their figures but I think they measure it at 0.5m from the rear of the car, at a 45deg angle to the length of the car and the same level as the exhaust outlet.
#85
From looking under my car, there's a slim silencer-like thing in the 'centre' pipe. I think the Ti-R has nothing at all but just a straight pipe right up to the tail silencer.
As I recall, the Ti has a 70mm pipe diameter and a 115mm tip, the Ti-R has an 80mm pipe diameter and the same tip.
#86
Originally Posted by atlvalet
You could also add resonators to an exhaust you already have too.
Could u please tell me where to find them? I've never seen resonators on any vendor's web site. My Logic Perf. catback makes great power but it is too loud (no cat). I'm thinking about going back to stock or get a quiter TB.
#87
Originally Posted by EVOfunk
How?
LPI/Megan makes a resonated test pipe that will quiet the exhaust down a lot. LPI has it listed on their site. I just took LPI's off my car in favor of a straight pipe. Its for sale if your interested.
