notchy 3rd gear
Old Oct 21, 2005, 01:29 AM
Evoegg's Avatar
Originally Posted by Mookie
Mine does it in third gear as well. Only at lower rpm's and when it isn't warmed up. I have BG syncroshift for fluid and it helped a little. When I run second to 4500 or above it usually is fine going into third. Oh, and downshifting from fourth to third is no problem.
you got brand new 05 ?? mine does the EXACT as yours and mine is new 05 .. and the tech told me shift all my gears at 4k rpm above .. kinda BS .....
Old Mar 8, 2006, 11:24 AM
Kica's Avatar
Has anyone experienced the notchiness, over time, turning into a grind? I have an '03 (with only 23,000 mile) and experience the notchiness, especially when it is cold. When warm it occasionally notches.
I am scared of the notch turning into grind and the warranty running out.
Old Mar 8, 2006, 12:36 PM
Chukee_R's Avatar
Mine does the same thing...It comes and goes through, haven't really narrowed it down to a specific time when it occurs.
Old Mar 8, 2006, 01:22 PM
Rnm
Rnm's Avatar
Hmm, my third gear is smooth to get into daily, however 4th gear is a bit notchy for me, but I don't mind it.
Old Mar 8, 2006, 01:31 PM
worksevo8's Avatar
Had my 03 with my 5th being notchy. Eventually it did turn into a grind, but traded in the vehicle before anything else went. It grinded when it was cold, warm, when I put it in slow, when I put it in fast, when I put in low rpm and high rpm. This is one of the reasons why I might not purchase another EVO I am tired of paying 27K+(depending on the model) and having issues that we should not have! If I do purchase another EVO, it will be used and I am going to redue everything, especially the tranny and clutch. No use in buying a brand new vehicle and having to do all of that right away. Just my .02
Old Mar 9, 2006, 09:40 AM
Kica's Avatar
I called a few dealers and they said to bring it in. One said it might have something to do with the clutch. The subtitle under his statement was:"I'm going to try to blame you for a flawed synchro." He went on to say that they will remove the clutch first and if its ok they will tear down the tranny and see if everything is ok. I will give it a few more thousand miles and see if it gets worse. Bothersome though that this could occur at 23,000. Makes me wonder how the rest of the car will last. I'll keep you all posted.
Old Mar 9, 2006, 10:44 AM
Doogie Howser's Avatar
Isn't there a TSB for 03 for 3rd and 5th gear syncros?
Old Mar 10, 2006, 07:21 AM
Kica's Avatar
Another gentleman, on another thread, was kind enough to direct us to it:
https://www.evolutionm.net/forums/sh...ferrerid=44684
Old Mar 10, 2006, 07:28 AM
matt55's Avatar
Originally Posted by 03SilvaEvo
Pennzoil Syncromesh
How many miles is on the fluid and when did it start ?
Old Mar 10, 2006, 09:33 AM
TimDC2x's Avatar
My 3rd gear is smooth as buttah, but my 2nd gear is impossible to shift into in the mornings (hence I normally do a 1-3 shift).
Running stock fluids.
Old Mar 10, 2006, 10:35 AM
jqturbo's Avatar
That's how mine is also. Noticed alot last night actually when I was shifting slow. It's different with different cars cause my 2nd is smoothe as can be, but 3rd is notchy. I got an 03' VIII with 12K miles on it.
RATEDX
Mar 31, 2016 09:38 PM
Kracka
25
Nov 14, 2008 05:50 AM
Grey Razor
17
Nov 18, 2006 05:22 PM
Blitzbaster02
Mar 13, 2004 11:48 PM
xtnct
Feb 17, 2004 02:29 PM
Quick Reply: notchy 3rd gear
