notchy 3rd gear
notchy 3rd gear
What causes it? Is it the shifter itself or the shifter bushings and underhood bushings? If I install just shifter bushings and underhood bushings will that eliminate the notchiness?
Originally Posted by Dan2510
I have the same feeling in 3rd gear however, it doesnt always do it. Though, I've noticed when I shift into 3rd at lower rpms I get it.
I would think it would get smoother over time, and I also notice it gets smoother when the car warms up.
BTW how many miles you have on your Evo?
well I been to local Mitsu dealer couple times and they told me its fine ........ I even have some axis noise but they said this car supose to have some noise .. dont know if its true but its what I have got from 3 different dealership ..... so I guess i am going to local car shop pros and have them to check it out ....
Evo = 120% worth the money
Mitsu Service = 100% wasting time.....
ok hope everything is ok...
Originally Posted by 6-speed
I noticed that too in my Evo, and I have about 670 miles on the car.
ineedevo: your 2-3 gear synchro might be going bad ...
Originally Posted by ineedevo
i always grind my 3rd gear, the cluch is all the way in but still it grinds wuts up with it ?
Mine does it in third gear as well. Only at lower rpm's and when it isn't warmed up. I have BG syncroshift for fluid and it helped a little. When I run second to 4500 or above it usually is fine going into third. Oh, and downshifting from fourth to third is no problem.
You guys won't always get a smooth shift into 3rd.
1st gear...triple syncro
2nd gear...triple
3rd gear...double
4thgear single
5thgear...single
As you can see, you have to go through 2 syncros to get in 3rd gear. If one of the syncros don't line up. You'll get that notchy feel. But if both syncros are aligned...it's buttaaah.
Lighter trans fluid might help. But I think it's just a normal thing to be notchy.
2nd gear...triple
3rd gear...double
4thgear single
5thgear...single
