Which 2 Gauges for EVO??? Help...
I am going to buy some gauges and a gauge pod for my EVO, I just want to know which gauges are the most important???
I was thinking for sure I need a boost gauge, however after that I get lost....
I only want two, so for our car and my 2nd gauge do I need EGT or Fuel Pressure or Oil Temp???
Thanks!
Thanks!
Thanks!
Thanks!
EGT makes the most sense.
Originally Posted by PurgeIt
How about oil pressure?
Get AFR and Boost. All the temp gauges (EGT, Oil, Water, Trans) warn of impending doom.
went to a local shop and I asked 3 meters with panel and install ~ comes up with around $1200 is this a normal price ?? DEFI Oil Temp, Oil Pressure and Boost ...... with a panel at the audio (none Carbon one)
I not sure about the price in other areas please give me some input .
thanks
thanks
Originally Posted by AWDrift07
oil pressure is essentially worthless, by the time you notice a change in oil pressure, the damage is already done. oil temp is a better choice.
A/F gauge is the one that is of no use .. those things are 70% not accurate 70% of the time ..
thanks
thanks
Maybe you didnt read the posts prior to yours so I will sum it up for you
Oil pressure is pretty much worthless.....and IMO I would not opt for a oil temp guage but if you want to fill up a spot by all means.....
Boost and EGT is all you really need
k I see . so most temps + boost and EGT? k ...was wondering the price=)
but thanks for the info man
