Hallman-vs-Forge
Hallman-vs-Forge
I have been looking at making my first engine mod to be MBC. The only problem is , God there are so many of them. So, i do my seaching (before War pops off at the mouth like a jacka$$ once again) and the two most popular MBC's i have seen are Hallman ( excuse my spelling , i think it might be hallaman) and Forge. What are the differences between these two? Does one do better than the other or are they all the same ? There are generally inexpensive parts , but i would like to get a really good part instead of suffer the trials and tribulations of those of you who had to find out the hard way which was better.
Both MBCs are spoken of highly, work wonderfully, and are inexpensive. The Hallman is much more common mainly because the Forge just recently hit the market. The main difference with the Forge UNOS is that it has a ratchet-style knob that clicks as you turn it. For those of us who have had MBCs for the last 7-8 years, we know how important that is. For newbies, it may not be as apparent before purchasing, since they haven't experienced it. What happens with a regular MBC is you don't really know how far you've turned the knob unless you have a mark on the knob as a frame of reference. Even then, you can never get it turned to the EXACT spot everytime. With the Forge, since it has clicks like a ratchet, you can keep count of how many clicks you've turned so that you always know where you are and how far you've gone.
There may be another aspect to the Forge in that it _may_ hold boost a bit better with less taper, but I'm not sure that has been proven. Al @ Dynoflash loves it and says it is a little better than the Hallman, but he still speaks highly of the Hallman as well.
hmm..
forge:
-ratchet style for turning
-silver or black
-a tad thicker than the hallman
hallman:
-it's red
-has capability of tuning inside car with the pro
-tad skinnier than forge
other than that nothing to my knowledge
forge:
-silver or black
hallman:
-it's red
Oh War you know i am just giving you $hit, like how i speling things wrong on purpiose just to get a rise outta ya . I also know you like ripping the $hit outta poor Noobs that just joined and might scare off someone who potentially needs a good amount of schooling about an important issue... but i digress. I think i would probably side with Al seeing how i like a more "exact" tune than a hit or miss "just spin it " kinda MBC. Other than the MBC i'm ordering a sterring column mounted boost gauge which i am sure i would need before i install the MBC (DUH!!!). But yes i have learned the importance behind searching which gave me a more profound understanding for the need of a MBC. Plus why would i need to have a remote to adjust the boost settings in the car ? Put it at 20 PSI and lett'er ride. My only concern is this being the only engine based mod i have, will this damage or hurt anything ? I want a TBE from Bushur , but we all know how expensive that can run.
The Buschur TBE is not that expensive compared to most exhausts. You can also get a Megan or LPI 3" catless exhaust for $550-600 if price is an issue.
Ok, i will play dumba$$ as always War. Why would you need to change your boost ? Wouldn't you always want it at full boost. I mean i understand if you have a turbo upgrade, but i am not that far yet . As for the cockpit control, i'll open the hood ! the price isn't worth the convience and i just don't see the need. I mean i know that once i install the part its good by warranty but , what the is use of having the car if its not really driven. Just need to be carefull when having fun and not have too much fun. What do you think War ( believe it or not i do listen to the more experienced advise) if you had to choose over again , what would it be F or H ?
Ok, i will play dumba$$ as always War. Why would you need to change your boost ? Wouldn't you always want it at full boost. I mean i understand if you have a turbo upgrade, but i am not that far yet . What do you think War ( believe it or not i do listen to the more experienced advise) if you had to choose over again , what would it be F or H ?
I am very intrigued by the Forge, but I can't say for sure that I'd buy it if I had to choose again, because I haven't PHYSICALLY used one or seen one used. I tried to get a demo that I could try out and provide feedback on, but Forge wasn't interested in providing one to my sponsor, so I might never know first-hand. If it works as well as advertised, then I'd prefer the Forge due to the ratchet knob.
So when driving on an everyday road doing whatever it is you do to be able to mod your car so well (druglord) what would you run your boost at and why ? Oh, and do you have a turbo upgrade ??
Oh and DAN, he's right me and War have a funny way of communicating. Thanks though.
well if you get a flash you can adjust your boost,but how reliable is the boost if you do both you can not only keep the boost consistant but you can adjust to fit your every day driving to race at ease.One thing im not sure about do you need a boost gauge if you get a flash with boost adjustment?
