Oil Change
Originally Posted by CICreations
You know, I really don't recall looking for a part number..I just grabbed one out of the display then had at auto zone. I checked the threads and everything and it matched up. Im not sure if there's really a difference in oil plugs with different car manufacturers.
http://www.royalpurple.com/techa/whyrpa.html
http://www.royalpurple.com/techrp/summary.html
Independent studies done on royal purple against all major competitors. There is a reason it is 6$ a quart.
I change mine at an auto hobby shop on the Marine Corps base I work at. They take the old oil and filter and everything. And I only pay $2 for the lift time. It's a great deal. But if you don't have access to that you can take it to auto zone I think and they will dispose of it. Some city dumps have facilities to take your old oil.
Or as Tyler Durden says id you know used motor oil makes great a great fertilizer. LOL....oops I broke the first rule!
Because the factory is using mass production and has a contract with mobile one. Just because Mitsubishi uses it doesn't make it the best. Take the Spark plugs for example. I can get 4 NGK IX iridiums for 8$ ea. A set of factory plugs is like 64$.
I agree but, if you call NGK they will tell you that the factory plugs are better.
That really depends on the car. Stock to stock maybe, but the higher end NGK IX's will out perform the Mitsu plugs. By higher end I mean the 8 and 9B series. Now in regards to the oil Royal purple is also a full synthetic and has been proven to actually polish the internal walls of your motor.
Not very many people will "out drive" their oil if they use a full-synthetic and change it after every track event! or oil change interval for street use. I think the selection of weight is even more important then the brand if using a full-synthetic.
I do not think royal purple is a Ester based oil?
Originally Posted by Eveolicious
What do u guys do with the old oil, that u drained from the car?
Mark Hubley
Lancer How Tos / Installations
Dec 29, 2007 09:16 AM
Mark Hubley
Dec 29, 2007 09:14 AM
