Hood Vent Cover Removal
Old Nov 13, 2005 | 04:31 PM
05SilverEvoVIII's Avatar
Its on their for a purpose to vent the rain in layer instead of falling on one desired spot, leave it on when it is going to rain, unless you are sitting in a garage.
Old Nov 13, 2005 | 04:48 PM
Sinister Subaru's Avatar
Pardon my ignorance, but what purpose would removing the hood screen serve?
Old Nov 13, 2005 | 04:51 PM
Curt@MrLed's Avatar
Former Vendor
looks and helps get rid of heat soak when in traffic, but mostly for looks..
Old Nov 13, 2005 | 05:06 PM
hardt45's Avatar
just removed mine, and I have to say I think it looks pretty trick. this has gotten me wanting to do a little clean-up in the engine bay now...has anyone else got the rust around the bolts on the heat shield and manifold? is there anything you can do about it - paint them or something?
Old Nov 13, 2005 | 05:15 PM
marks03evo's Avatar
it is simple dude no worries
Old Nov 13, 2005 | 10:14 PM
Jakeg97's Avatar
everyone gets it.
to fix: go aftermarket
Old Nov 14, 2005 | 05:45 AM
C6C6CH3vo's Avatar
Channels water so it drains better - less corrosion in rain
Hood is shaped in such a way that air flows over the top creating negative pressure over the vents which slightly help draw air from the bottom and front.
May also serve to draw heat away from the painted surfaces on the hood. Prolonged heat decreases the durability of finishes.
Bottom line: Other than water drainage and looks, doesnt really serve any real purpose. If you have a nice tubular to view than show it off, just resecure the screws and clips to keep the other stuff from flapping in the wind.
Old Nov 14, 2005 | 05:58 AM
evo 8 ya's Avatar
Originally Posted by EVOtagger
i also take mine off all spring and summer and fall...i only put it back in during the winter so snow doesnt accumulate inside the bay
That's what I do too. Unless I know it's going to be raining like a bi*ch then I'll put it back in. Looks hard with it out though
BOOSTINAT30PSI
Sep 6, 2018 08:05 PM
wewtRallywewt
Mar 23, 2016 11:35 AM
hereitcomes
Nov 8, 2012 12:20 PM
nhclubowner
19
Nov 8, 2005 10:49 PM
Lightsped
Jul 25, 2003 06:21 AM
Quick Reply: Hood Vent Cover Removal
