A friendly word of advice to all new Evo owners...
I recommend that those who buy a new Evo have the alignment checked immediately. I had mine realigned yesterday. The car only has about 16,000 miles on it, but the Advans were worn almost bald on the inside while there was plenty of tread left on the outside. The tech said that factories are sometimes not that diligent when it comes to aligning their new cars to the exact specifications. On mine, the toe was off considerably (though the camber was fine). It was enough to shorten the life of the tires.
By the way, I had to get the factory specs for the 05's from the dealership. The alignment shop didn't even have them for the 04's. Just a thought.
Originally Posted by DCSilvrEvo
What are the alignment specs on the 05s? also on the 03s they have more aggressive camber for road racing purposes.
Yeah i just finished purchasing a set of new yokos yesterday at 14,500 miles on my 03 evo. The advans were so bald i would loose traction on the rain. Very scary on the highway.
Just changed out my tires yesterday. I had 24,000 on the stock ones and there was still some decent tread left. Got the same brand but went down to an "H" series with the winter heading this way.
Allignment was also off a bit. It took Michael tires over an hour to get it right.
Still on the stock clutch too. She still holds the same as she did when I bought it. Then again, I don't beat the s''t out of it either. You treat your girl right, she'll treat you right!
Make sure you rotate every other oil change.
you advans lasted 16k thats fantastic. After 16k your evo should have hit a pot hole or two I doubt it was bad from the get go. If it had been your tires would have never lasted 16k, try 4k.
after about 10k miles...my passenger front tire was shot......the inside was all worn and tearing up, while the rest of the tire was fine...now my driver side front is having the same problem...while the back two are not as bad as the front one's but are still a little worn out than the outsides....
