Evo Diet
lose the passenger seat and get a lightweight replacement for the driver seat, get a smaller battery to replace the heavy stocker, lightweight rims, lose the wing i dunno those are a few things.
if your building a RACE CAR why not go all out then and remove the AC etc and what not I dont understand..
Thats my problem I want a racecar but I also want my street car and cant afford two Evos so I am trying to do the best I can. I already have a smaller battery, my wiring I need for street driving. Does anyone have any real weights for this stuff... like for 2 grand worth of rims and saving 10lbs isnt a great $/lb.. I would rather start with something like seats, steering wheels, airbag type stuff.
I just dont know how to get the seat rails and everything to work for the seats, and have no idea on how to go about tossing the airbags and controls for them. Id bet the whole airbag system weighs 50lbs.
Lightweight and relocated battery, front and rear 5mph crash beams, CF driveshaft, and remove sound deadening material from under carpets in cockpit and trunk.
Those are just a few that I can come up with off hand.
Originally Posted by TrinaBabe
Well it magically lost around 100lbs. Thanks for the good input moron.
get real man, i mean come on, this topic has been covered a thousand times on what can be removed to save wieght, research, your post just made you seem like your either lazy or cheap, you want another idea? how about you take your seats out and carpet and get your hair dryer and scraper and start going at the sound deadening crap on the floor?
search.
"I am wondering if anyone took the time to actually weigh out alot of the components of the car."
That is what the post was more designed towards... and I have read plenty of weight savings the problem is most are either 'gimmes' like you said or are designed for a flat out race car. I have an RX7 that is designed as a pure race car and it is stripped, without heat, glass, some of the various metal bracketry, holes drilled through, etc...
I was looking for weights of various componants mainly and some more ideas of 'gimmes' as you say. Or maybe some info on where i could buy some lighter weight componants (Like the doors).
