HOW GOOD IS STOCK Recirc Valve
COULDNT FIND THIS ANYWHERE WHEN I SEARCHED?
JUST WONDERING FROM OTHER SOURCES HOW GOOD THE STOCK VALVE WAS BEFORE IT STARTS LEAKING? SHOULD ONLY BE RUNNING 21.5 PSI
DO I REALLY HAVE TO BUT A FORGE RECIRC TO HOLD BOOST!!!!!
MODS 2005 EVO
1. HKS RS INTAKE
2. JIC DP/PERRIN TESTPIPE AND CATBACK EXHAUST
3. WALBRO 255 FUEL PUMP
4. TURBO XS MBC
5. SOON TO HAVE CUSTOM DYNO FLASH TUNE
MODS 2005 EVO
1. HKS RS INTAKE
4. TURBO XS MBC
mine leaked starting at 5 or 6 psi so i bought a forge and can hold boost at 22 psi without taper now. before it would hit 21 and taper a bit to 19.5 or so. I would rec at least a jdm BOV, a forge isnt really necessary, but i dont want to ever spend $ on a BOV again so the forge will be the last. JDM is good to 25 psi or so.
Stop typing in all caps.
anyways, The stock 06 EvoIX bov is metal unlike the 03-04 ones so they should hold a bit better than the plastic ones. I would recommend the APS bov, if you wanted you upgrade... your money... your choice!
anyways, The stock 05 bov is metal unlike the 03-04 ones so they should hold a bit better than the plastic ones. I would recommend the APS bov, if you wanted you upgrade... your money... your choice!
