Why did my speedometer stop working.....?
I was just driving and it just stopped working, the code Vehicle speed sensor malfunction came up..... ya think.... (also the odometer stopped as well)
anyways I check the connections, on the dash everything seemed to work. but I havent checked the fuses, or ecu end of the connections.
any other ideas?
thanks
dustin
any other ideas?
thanks
dustin
any other ideas?
thanks
dustin
any other ideas?
thanks
dustin
If it threw a code(p0500) the ecu is not seeing any activity from the speed sensor,possible that a loose connection,possibly a bad speed sensor.If your speedo was not working but you did not get a DTC(diag trouble code) then I would say check your speedo head,but seeing you got a code and your speedo is not working I would check your connection at the speed sensor,and or the sensor it self for a malfunction.
Originally Posted by westchester evo
On the top of the tranny under the upper boost hose is th VSS sensor. Make sure the plug is in. I had my clutch changed and it was not pluged in.....
VicVoss
Sep 28, 2016 06:37 PM
SatsuMX
Lancer Troubleshooting
Feb 22, 2016 08:38 AM
