3 problems should i contact a dealer?
1. front end alignment chewed up my front tires inside tread. Car has 6k miles.
2. Near the Oil filter "not the oil filter" is driping oil very slowly
3. Fuel temp sensor is throwing a SES light. Checked with a laptop
Now if i go i am going to catch hell with my mods. Is this worth it or should i fix these problems on my own with local shops. These should be all covered with warranty unless the fuel temp sensor light was caused by my fuel pump. But the evo manual says the sensor is not near the fuel pump and another cause could be in the ecu. You guys think i should take it and have to worry about talking to an area rep cause i know that what they are going to have me do...
As for tires WOW never heard of that problem!
Any mods on your oil line?
Worst thing that will happen is that they say no and void ur warranty. Its not like later down the line ur warranty isnt going to be voided anywayz. If ur manifold were to crack and u take it in to the dealership they would still say no and void ur warranty. Some dealerships dont trip about it tho. I have intake and upper IC with HKS BOV (Clearly Visible) and MBC. They didnt void my warranty when i took my car in to get my transfer case fixed. There was a oil leak on my TC. They gave me a rental for 5 days and fixed my TC.
The front tires are chewed up (worn) on the inside from the negative camber setting from the factory. The wheels are cambered like this for better contact patch while in aggressive turns. I think the book says to rotate @ 5k miles or something. If you drive REAL aggressive (like I do) you will need to rotate at 3500 miles or so. The tire wear is real bad on the factory tires ... but I dont mind because of the awesome handling they provide. ( Softer wears faster always)
well i rotated at 5k. The problem existed before it. So the oil driping isnt a huge problem but an annoying one as it is driping on my garage floor..it probably leaks a quart every month or 2. So very slowly. I had a buddy install the fuel pump for me. I checked it today and didnt see any damage to the top of the pump. Now the manual says the ecu could be at fault. Maybe we missed connecting it back to the ecu? I dont know.
1.) its aftermarket
2.) you didnt have installed by a "professional mechanic"
BTW I work for a Mitsu Dealership! Fix this stuff yourself! Or dont tell them about your mods!
Thanks,
True...everything is covered under 12K. Stock, though. Like mentioned above, if you can find a reasonable dealer, you shouldn't have a problem. By reasonable I mean one that realizes that tire wear has nothing to do with your mods. You're taking a chance on the other issues.
reason i raise the question is because i have no clue on how to fix the fuel temp sensor....the oil leak thing is a oem defect because i never once touched it..plus now i have to get new tires soon because the cars camber is screwed from the onset?
well i guess the fuel temp error isnt that big of a deal cause its not causing any power loss and its just a SES light error...tires i can live with..now the oil i guess i can get a local shop to fix
Originally Posted by Mark Sebby
they will void that fuel pump...
1.) its aftermarket
Thanks,
1.) its aftermarket
Thanks,
If your local dealer is the kind that thinks that any mod is a reason for warranty restriction, get a different one. You reap what you sow. Lieing to them would only slow the process and cost YOU and the dealer more time and money.
Mark, if you work for a dealer and you are promoting lieing to the dealer then shame on you.
