downpipe making creaking noises?
does your downpipe make any creaking noises when the engine is cold or when the rpm dips below 800rpm which causes the engine to vibrate more? I think its the spring thats making the noise where the downpipe is connected to.
What downpipe are you using? How long has it been on the car?
I put a used generic downpipe on mine a few months ago, it came with a hks carbon/ti I bought used. Turned out it was touching my oil pan. Not good. It was rubbing on the pan causing a creak sound sometimes. You might want to check your clearances. I switched to a turboxs dp, correct fit.
Many DP's have fitment issues
After analyzing the existing aftermarket DP's on the market, we found most had poor fitment issues, questionable weld quality and did not maximize to a true 76mm system.
Because of this situation, we decided to produce the only DP that fits perfectly, looks great and is a proper 3 inch system-
The WORKS 76mm DP comes w/ a stamped flange and gusseted hangers so the fitment is just like Mitsubishi's. Our engineers designed the system to match perfectly to the stock system and meet our standard of "OEM or better.
http://www.worksevo.com/store/produc...products_id=93
-the choice of Cyber-Evo and Evo engineers worldwide!
