Evo IX STOCK dyno'd at Topspeed with VID
I am amazed at what this car did stock. I didn't think the numbers would be anything like this. To start off, this dyno is right on the money. My 04 VIII stock put down 217awhp and once I added TBE/Dynoflash/MBC @21psi it put down 284awhp. I decided on my IX that I would give it a really nice breakin. First day, I drained the oil and put in mineral oil. I drove the car for 500 miles without going above 3500 rpms. At 500 miles, I put back in mobil1 and drove easy for 400 more miles going into the higher revs very slowly upwards of 6000 rpms. At 900 miles, I started beating the crap out of it. A lot of you said that this was not needed on the evo and that you should break it in like you stole it. Car now has 1200 miles and I knew that this thing was quick and I thought it felt as fast as my old car. Totally stock EvoIX with slow breakin put down 270.48awhp and 265.34 torque. Remember that this is the SAME dyno my VIII put down 217 stock. That is a HUGE difference!! This would make the rated hp on the car a lot lower. I would highly suggest slow breakin for all the future evo owners and wish I would have done this on my VIII.
Click here to watch Evo-IX-Stock-Dyno-Run-TOPSPEED
Boost spikes to 22.5 psi and tapers to 18psi by redline. These should be exact as I have the defi BF gauge and controller. I will be getting ecutek tune and doug says I will be over 300awhp with just a flash. Simply amazing car!!
Everything that I say could be potentially wrong, but I don't think that your 270.48awhp and 265.34 was totally depending on the slow break-in period alone. I mean it is a totally different car and it doesn't seem like you dynoed that Evo VIII on the same day either so with different conditions, it just doesn't seem like everything was dependent on the slow break-in period. I could be wrong about everything though, so don't listen to me.
mobil1 has detergents for an engine that are really not needed in breakin. This is all imo though remember that, not trying to start argument over breakin, but if you drain that out and put in mineral oil or some cheap oil with no detergents it supposedly makes rings seat better. I have many friends that have done this so I decided to try it this time.
Originally Posted by Enyth
is the higher hp due to the larger turbo or the mivec or both? cuz i thought that the mivec was for the tq?
This has been discussed in several of the IX tuning threads. The larger turbo is responsible for the higher peak power, and the MIVEC is responsible for spooling this turbo even faster than the previous turbos. The MIVEC helps boost low-end torque and mid-range power, so even if you have a IX that dynos the same peak numbers as an VIII, it will have MUCH more area under the curve, because it's less peaky and more steady, which makes it MUCH more enjoyable to drive.
I am loving it
Originally Posted by el producto
Thats awesome. When does boost kick in on the IX if it spools faster cuz my 05 starts around 2800 then really starts to pull at 3500.
I cant watch the boost gauge closely, becasue I am looking at the road flying by, but it does boost around the same time at like 3000rpm and maxes out at 3500rpm. My car then stays at 20psi all the way to redline, myabe goes down 1-2 psi, cant really tell cause am concentrating on the road.
