CEL Problem
jus got it for the last few weeks... since the cold weather started here in nyc. i had the code checked by several diff mechanics and all said they are not sure wut it is.
my driving habits have been the same. its daily driven on the streets of nyc. i do get the occasional urge to punch it ... but the car is never reved above 6500 rpm
any helps or tips would be appreciated...
Originally Posted by Elite Evolution
Same here, ever since the cold, CONSATNT CEL's. During the summer I was perfectly fine, now this poop.
well i got a CEL but i was running one step colder plugs, changed over to the stock heat range and everything went away i was gettting RPM higher then expected, this could of been both because of colder plugs or because the plugs were slightly fouled, check your spark plugs takes like 10 minutes, and if they look black as hell, replace with BPR7ES or the iridium ones.
