It's a Warrtalon Christmas...
Originally Posted by Sackett
I installed my UNOS a couple weeks ago, its teh hotness. put in the stiff spring, turn it about 6 clicks in
i just got off the phone with jarrod a couple of hours ago, and have purchased Buschur's Stage 2 and Stage 4, Lower I/C Piping, (I already have stage 1 minus the flash tho) the EVO is in storage right now (yeah yeah let the bashing start) and i will be getting the flash once i have all that stuff in. i also ordered the Autometer Boost gauge i have an OBX, but want something can you say better! And the last thing i got from Buschur was the Spark plug Cover (which are being CnC'd right now.) i will rec. everything around the end of next week jarrod said, and the spark plug cover as soon as it comes in from machining
Its not just a Warrtalon Christmas its a GTSMWET Christmas also!! MERRY CHRISTMAS!! Have fun Warrtalon
I am glad to see you are getting more mods. Those are very good parts. I was at the Forge shop for most of the afternoon today. And I also got the same parts from them, and picket up some more stuff today. Nice produtc and good people.
Ask them about the Samco Evo IC hoses. I think they are clearing them out for allmost nothing.
That's what I'll be doing tomorrow. Slap in the stiff spring (if it's not in there already), and do a few clicks for 21-22psi, but that's only until the Forge WGA shows up, which I will set to 20psi stiffness, then put the soft spring back in the MBC for minor adjustment.
Make sure you do a post about the results with that wg actuator. i was looking into getting that too, but i may save my money for a 20G-9, which has a redesigned actuator, so the 8 actuator wont work. I'd still like to know your results with it tho.
Originally Posted by AndyBandy
how much of a PIA are the motor mounts to install, any idea??
Hopefully, I can improve my times, but unfortunately, the next time I hit the drag strip, it will be at 5000-6000' above sea level, so it will be hard to beat my current times. However, I do hope to be able to show some dyno increases before and after while still at sea level in January.
