What harnesses can be setup for rear seatbelt anchors & unclipped for daily driving?
Originally Posted by WarmPepsi
theres not, and i have one sole reason for it. to install them, and use them as designed, you have to undo one of the clips, as we have 2 holes for belts, where (for example) the rsx has one, the thing slides through, easy.
to get it through ours, you have to do a 10 second disassembly of the little plastic tightener piece. Not hard at all, but a good reason why they wouldn't have an application for us.
The rear portion of the belt is mounted to the rear seat belt locations
I can provide pictures if you want to see how the belts are installed if your interested.
Originally Posted by chrisw
I already know what your talking about. I have a Rallye 4 harness installed. It was a PIA to install, but once installed, I leave the belts drapped over the seat when not in use.
