Help me spend some Christmas cash
#31
He only said that "it will hold the desired boost closer to redline," which is true. Of course, the boost still tapers, especially after redline (7k), but as he said, an MBC "will hold the desired boost closer to redline" unlike the stock BCS.
Thats all I wanted to know about the MBC. It holds boost better after the spike. Was that so hard?
#33
Originally Posted by BADEVO
HUH????????
The MBC increases the boost so it holds better to the redline. I notice the boost top out at 4500 rpm then drop off.. i guess the MBC improves on the amount of loss after the spike and holds the boost better than stock. It seems wierd this is the most popular mod due to the fact you can really do some damage. But then again im not the expert like all of you are.
#34
No, the MBC just takes control of boost away from the Boost Control Solenoid. That's it. It sets the boost wherever you want it. A side-effect of this is that it takes the Boost Control Solenoid out of the equation. It's the BCS - by command of the ECU - that FORCES the boost to taper early and down to a much lower level. With the MBC, there is nothing forcing the taper, so the only taper that occurs is the natural taper caused by the turbo running out of breath at high rpm. What we do is RAISE the boost over stock, because we can safely run more boost than stock on pump gas and MUCH higher boost when on race gas or alcohol injection. For instance, I run 21-22psi on 93oct and 24-25psi on race gas (100-116oct).
An MBC is only as dangerous as its owner, which is why we've all suggested that you NOT get one (or any additional mods for that matter).
#35
#36
You only suggest the JIC because it "fits" the 05? Are there any that DON'T fit the 05? Also, if you have to space the lower brace or change the brace, then I don't really consider that to be a part that "fits." Is it cheaper than the Megan DP that fits without spacers?
#37
Originally Posted by nj1266
More clarification: When I said fits I meant that it does not hit the ACD or the oil pan. JIC is also a 3 inch dp and most of the 3 inch dp that I know of do not clear the lower brace. Maybe the megan is different, I do not know. So you either have to space it or you have to use the RMR brace. I went with the RMR brace because it is stronger than the stock one and adds more rigidity as well as clearing the 3 inch JIC dp.
#38
Sheesh.
Dont get anymore mods? I can bolt a test pipe on and get 20 whp. Every turn of the dial will produce more or less boost.. i understand that. I just wanted to know what exactly it did.. i thought thats what this forum was for but i guess i am too much of a novice.
#39
Dude dont take it personal, if you do then you'll never get anything out of a forum. Problem is people ask questions and dont want to hear REAL answers. Have a thick skin.....
#40
No, you won't get 20whp from a test pipe.
No, this forum isn't for asking a question about the most basic of all parts on an Evo or any turbo'd car - the MBC. Especially when the answer can be found with even the slightest attempt at searching, but that shouldn't even be required...it's common knowledge...it's like putting in the highest octane at the gas station.
#41
Its cool.. all i wanted was the real answer as to what an MBC does. All I did was get ripped for not knowing enough and told to leave my car stock.
#43
#45
Why would I need to go there when I have a test pipe myself?
Edit: Nevermind, believe whatever you want to believe. I don't care. I spend enough of my time helping people who actually take my advice and use it to go fast for less. I think you know that, because you invoked my name on the first page.
