5th gear RPM???
Old Jan 4, 2006, 03:32 PM
WarmPepsi's Avatar
Originally Posted by keevo54
Check owners manual for lowest speeds to travel in each gear. My IX says 45mph in 5th is lowest but says you can go a little lower with little to no acceleration.
haha, thats a novel idea.
Old Jan 4, 2006, 04:07 PM
AlwaysinBoost's Avatar
good call, RTFM
Old Jan 4, 2006, 04:09 PM
Soon2BEVO's Avatar
Originally Posted by AWDrift07
It's bad for the main bearings/TC to put it in a high gear at low rpm with WOT. If you're cruisng at 40 and have the rpms around 2k its normal/fine. But say you just put the pedal to the floor, same gear, same rpm, thats bad... Downshift to accelerate.
5th gear, 1.5k rpm cruising is the lowest you should go IMO. Any lower and you should downshift.
It's bogging/shaking because you're asking the engine to do too much work out of its optimal powerband. And you will slowly kill your main bearings/ TC.
This man is correct!
chetrickerman
Jun 23, 2017 10:02 AM
pb91
Jun 8, 2011 02:44 PM
gmore84
17
Apr 21, 2008 10:20 PM
EricH
14
Feb 9, 2007 09:36 AM
xkpbreaker
Apr 28, 2005 09:37 AM
Quick Reply: 5th gear RPM???
