Blowing apart the stock gauge cluster...
![Question](https://www.evolutionm.net/forums/images/icons/icon5.gif)
Has anyone taken apart an EVO cluster completely? Does anyone have diagrams or written instructions on how to do this? I've seen threads showing how to change bulb colors but I'd like to know if you can remove the tach, speedo, lancer logo, fuel, and temp gauges from the bezel. Thanks!
Ed
Ed
I believe you can remove the gauge face overlays from the cluster as people sell gauge face plate overlays. Im not sure the result would be pretty however as these overlays are glued on. Once removed, good luck getting them on again. Id love to swap out the black faces for some nicer black and blue gauges, something easier to read and something that looks better at night. Not the ebay white face gauges though
Getting the cluster out is easy, but removing the stock gauge face overlays is not - as you have to remove the needles in order to get at them.
What's wrong with the eBay white overlay? It does not have to be glued on (though a light coat of spray-on adhesive helps), goes right over the stock gauge faces, and, if you wire it right (i.e. not according to the instructions), they look good in the day (read: no EL lighting) and at night (bright as-hell EL lighting).
l8r)
l8r)
The "lancer" gauge is actually pretty easy to remove. After you get the cluster out, just un-snap the clear lens and black mask (part that surrounds the gauges) from the white case. Under that will be each of the gauges and since the lancer overlay doesn't have a pointer it will come off by just peeling it, since it does have some adhesive on the back side.
The problem is that this overlay also has some warning telltales also such as intercooler, blah blah I can't remember the other few.
If you have a replacement overlay with the telltales but without "lancer" it would be easy and perfect to replace.
I can't stand to see "Lancer" in my cluster either. What I did was remove the overlay and mask it off on the back with black tape so that at least I don't have to look at it in the night time
![Thumbs Up](https://www.evolutionm.net/forums/images/smilies/smilie_thumbsup.gif)
The lancer gauge overlay (that's the plastic sheet that has the printing on it) also has on ith the telltales for intercooler sprayer and a few others, so if you just remove it you are also removing those telltales that you want.
If you were to just remove it or cut out just the lancer text then you would be left with a hole where you would see back into some ugly white plastic and direct light from the bulbs looking really bad.
What I would love is for someone to sell just the lancer gauge overlay by itself so we can just get rid of that part easily and cheaply without buying and replacing ALL the gauge overlays <-- suppliers listening?
tjacopi
Dec 7, 2004 07:24 AM
