diff in 03 turbo to 05
You are correct it's only the hot side. Now the IX turbo has a different compressor cover as well as the 10.5 hotside and a single flapper wastegate design instead of the double one in theolder models.
to elaborate, isnt it a 10.5cm3 sizing difference over the 9.8?
And also the 05 turbo has a single flapper wastegate opposed to the dual flapper of the 03, which means the port cover for the wastegate is operated by one valve covering a split port instead of a dual flapper covering the split.
What is the hp diff? cause I was thinking of just getting a 05 turbo and putting it on my car but if it is not going to make a diff. then I will just get the 10.5 hotside and do that.
KFC-AWD
May 25, 2016 07:04 AM
740 Turbo Brick
Jan 6, 2016 08:22 PM
Gorge
Aug 1, 2005 03:48 PM
