Who knows their physics?
Scenario:
You have Car A with 200awhp/200awtq and Car B with 200rwhp/200rwtq. They both have the same drivers (to avoid any realworld flukes) and they both weigh the exact same. They both take off down the track in a 1/4-mile.
1) Who will reach the end of the quarter mile "sooner"?
2) Who will have the higher trap speed?
Please explain your answers. Ignore all differences in friction (tires, etc..) with the exception of drivetrain. Both have identical transmissions and gear ratios, etc..only one is all-wheel drive and the other rear-wheel drive.
-M
-M
Well, in real life, the RWD car will trap higher unless on slicks and the AWD car will get there sooner, but ince you said to ignore friction differences, then I don't know. Parasitic loss has already been accounted for with the WHP figures, so it comes down to weight and gearing, which are also the same.
1 Post
Well, in real life, the RWD car will trap higher unless on slicks. Since you said to ignore friction differences, then they should trap the same speed. Parasitic loss has already been accounted for with the WHP figures, so it comes down to weight and gearing, which are also the same.
who ever has the better grip. if the RWD car cant hook the power to the wheels, then it just wont git....more than likely the AWD car will have better grip in the begining, and may lose some time at the end due to drivetrain loss, gearing, etc....too many variables i think.
If you ignore friction differences as stated, then differences between AWD and RWD would be eliminated due to the fact that if we are ignoring friction differences we are ignoring traction differences.
friction is a cruicial factor when comparing awd and rwd
Good analysis guys, but I only said ignore friction difference with relation to tires on the pavement (ie. the ground is perfect, the tires are the same, etc..).
I think that I will agree with the AWD getting there sooner and the RWD trapping higher assuming everything else is the same because of the fact that AWD will not build up speed like the RWD car would.
But let's get a little deeper. The trap speed indicates the current velocity at that particular point. Suppose we wanted to find the average velocity throughout the entire trip down the quarter-mile. We would have to break up our times into intervals to approximate the overall velocity down the track. Which would have a higher overall average velocity? If Car A gets their sooner, wouldn't it have the higher average?
-M
-M
-M
-M
Then again I was never good in physics.
Originally Posted by urBan_dK
Take the integral of the velocity vs. time graph and you get distance traveled. Both graphs will have the same amount of area under their curves since they both travelled 1/4 mi. Since the AWD does the 1/4 mi quicker, it must have a higher average velocity in order to achieve the same "area under the curve" in the velocity vs. time graph in less time than the RWD.
-M
