Virtual/Real Guages
Virtual/Real Guages
I have an OBD2 reader that I leave hooked up to the car. It has a virtual gauge cluster that persists of air temp, coolant temp, intake manifold pressure, maf pressure, fuel pressure, speedo, and tach.
This is from the program DigiMoto. Just a sidenote, but can't seem to get it to display the maf or fuel pressure gauges. Maybe our cars don't provide that info through the OBD2 connection? Anyways, I got the reader mainly to clear CELs and check codes, but this virual gauge cluster is not too shabby. I'm doing the three gauge cluster setup and was planning to buy an oil temp/pressure gauges and water temp, but I don't see the point in a water temp now since the program displays this gauge. Should I still get a "real hardware" gauge or go for something else? I also own the PLX R-500 so I don't need a boost, egt, or afr gauge. How accurate are these virtual gauges (obd monitors)? My coolant after normal driving hits around 200F. Is that a normal temp?
Sorry about the wrong temp. If you noticed, I edited it minutes before your reply . Phew that's good to know and also tells me that I might not need to buy a hardware coolant guage! What are your thoughts on this? I believe I can get away without one, but now I still need a third gauge for my pod. Maybe I should opt for a fuel pressure or maybe a boost gauge just to have something mechanical to look at. The R-500 boost gauge, being electronic, might get on my nerves more than I can handle. I'm going with the Blitz BLM so my choices are limited. It's either boost, vacuum, fuel, or egt. I'm already getting both oils.
I'd have to check with the software, but that's a great question. I doubt it since I'd have to somehow connect the real gauge through my computer and I don't see how that is possible. According to miki it appears that since my temperature is within range, that the obd connection itsself has a rather accurate reader built-in. So I'm asking why bother with a real gauge? And yes, I would need the laptop always plugged in, but that's not a problem since it will be integrated for in-car use. I'm leaning more towards buying a mechanical boost gauge now instead since I've heard that electronic boost gauges tend to refresh too quickly to keep track of boost drop and creep.
Lol thanks for the bump I was going to do anyways, but yeah, I'd love some more feedback. I'm about to purchase some gauges right now and I'm still contemplating getting a mechanical boost gauge instead of the coolant.
I actually tried that before the laptop. I had a 1GHz P3 with a custom fiberglass case that I had mounted under the driver's seat. It was a tight fit, but worked. I wanted to for-go an in-dash screen this time around since my last one was stolen in the M3. Plus I thought it over and didn't want pillar or dash mounted gauges if I could avoid it. Plus the laptop works great through an inverter plugged into the lighter adapter, but the desktop always overloads it. Plus, I'd have to drill through the firewall and attach new wiring to the battery on new terminals. I don't mind doing it, but I'd rather avoid it if I could.It's a small sony Vaio with a 10.2" screen so I can even mount it on my dash while the keyboard hangs down over the front clock and ac vents or I could even build my own laptop stand (which I was leaning more towards).
Check out MP3car.com . There are actually vga touchscreens available that can run resolutions of up to 1600x1200 (most of them are widescreen though). they were developed to basically solve the issue of being able to use desktop gps software and have it still be readable. But still, I'd take my 10.2" screen to a 7" anyday. So how about helping me decide between the fuel, boost, or 'just sticking with the water temp' gauge? Also, anybody know why the obd device can't detect maf or fuel pressure?
Originally Posted by Late Apex
have you tried maybe contacting them? They might know a fix? This is on your evo ix right?
Originally Posted by dryad001
digimoto
